Nintendo DS Lite not turning on | |
Device | Nintendo DS Lite |
Affects part(s) | |
Needs equipment | |
The device does not turn on when the power button is used.
- Power LED stays off
- Both screens stay off
- There is no sound
One or more part failures can lead to this problem. Compare your device to the following table to find the most likely cause of this issue. All test are considered to be done with a known good battery.
Symptomps | Actions |
Does charge, but not turn on. | Check power button / slider. |
Green light flashes for a second. |
Does not charge or turn on |
First, disassemble the device as far as needed to access the part you want to check.
Check the power button / sliter
The power button is located on the bottom side of the PCB labelled SW13.
- Pin 2 to pin 3 - shorted
- Pin 1 to pin 2 / 3 - open
- Pin 1 to pin 4 - open
- Pin 4 to Pin 2 / 3 - open
If you use the power button, pin 1 should now be shorted to pin 2 and 3. If that's not the case, you have a faulty power button. To make sure the diagnosis is correct, use known good parts to connect both screens and the wifi module, connect a charged battery (polarity!) and then short the power button pin 1 to pin 2 and 3 with tweezers. If the device turns on, this is the only problem.
Check screen ribbons and WiFi module connections
Make sure all ribbons are plugged in straight and not at an angle. All screens must be fully connected. Make sure the WiFi module is connected. The wifi antenna is not neccessary to boot. Then connect a charged battery (polarity!) and use the power button or short the power button pin 1 to pin 2 and 3 with tweezers of you have a defective power button. If the device turns on, this is the problem.
Check fuse F2
Fuse F2 is located near the power connector and the DS Game slot pins on the bottom side of the PCB. Check this fuse for continuity using your multimeter. If it is broken, replace it. Do not just remove the fuse and put in a wire instead, as this can and probably will lead to more damage if this isn't the only problem with the device. Replace it with a proper fuse.
Check for faulty WiFi Module
There are two ways to check this:
- Check the WiFi module to test in a known good device. If the device still turns on, the WiFi module is good.
Check fuse F1
The fuse F1 is located right next to the power connector and EM10. Check this fuse for continuity using your multimeter. If it is broken, replace it. Do not just remove the fuse and put in a wire instead, as this can and probably will lead to more damage if this isn't the only problem with the device. Replace it with a proper fuse.
Check EM10
EM10 is located right next to the charging connector and F1. Check for continuity. The pins parallel to the charging port should be connected. See Fig1 (to be added). If there is no continuity between those pins, or if there is continuity to other pins, replace EM10.
Check the power connector
Visually inspect the power connector. If you see any bent pins or other damage, replace the connector. Plug in a known good usb power cable. measure for continuity from the cable to the pins of the power connector.
