There are many reasons that could cause an iPhone 16 and iPhone 16 Plus to randomly restart every few minutes.
For the iPhone 16 Base Model series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged with a drop & the back glass is breaks. Or when someone has repaired the back glass.
Air Pressure Sensor - This part is located at the bottom of the housing & connects to the charging port flex. If it gets physically damaged or water damaged, it can cause 3 min restarts
Wireless Charging Flex - The flex that's attached to the back glass. It must be plugged in & not damaged, otherwise it will restart every 3 minutes
Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
iPhone 16 1572864 Panic Log Example for Charging Port or Air Pressure Sensor fault
After a back glass repair, the iPhone will restart on its own every few minutes
After a hard drop, the iPhone will restart every 3 minutes.
After a screen repair, the iPhone will bootloop every 3 minutes
After replacing the charging port flex, the device will auto restart on its own randomly.
The iPhone will reboot randomly when using it.
The iPhone will seem to freeze and restart every 2-5 minutes.
iPhone 16 Panic Log Example for Back Glass fault
For this model, look for where it says "SMC PANIC - ASSERT" ... "Sensor Array" ..
If you see:
1572864 or 524288 - It's related to the Charging Port Flex
Make sure this flex is plugged in
iPhone 16 Air Pressure Sensor. If not connected or damaged, it will cause panic log 1572864Check the bottom mic/air pressure sensor module is connected
Check that no flex is torn, liquid damaged, defective
Test with OEM or Premium parts.
Aftermarket Flexes have a high defect rate
If water damaged:
1. Check the taptic engine. You can test with it unplugged.
2. Check the air pressure sensor module is not corroded or damaged
3. Check the FPC for corrosion or loose pins
Diode mode the FPC connectors for any fault
2097152 - It's related to the Wireless Charging Flex
Test with OEM or Premium. Aftermarket Flexes have a high defect rate
169 - Battery Data Line issue
Usually it's stuck at 1% or displays 0% when you plug in the charger
Try a new battery or known good battery
Check the battery connector for damage. - If warped, loose or broken, replace the FPC
Diode Mode the battery data line pins on the connector
Check voltages on battery data lines
Replace U4000 and U4200
iPhone 16 panic log 169 is due to battery data is missing
3670016 - Sandwich issue
This panic can mean charging port and wireless charging port are faulty/not plugged in
This could also be a sandwich issue on this line highlighted in the picture to the right.
Test this test point to see if you have OL. If OL the issue is sandwich seperation or CPU separation. Reading should be .350, check for OL, if OL then you have sandwich issue or CPU seperation
iPhone 16 Back Glass - If you don't have this flex plugged in, it will cause 3 min restarts with panic log 2097152. The important part of the flex is the small IC where the red arrow is
It is also a good idea to keep a known good charging port flex in your bench, for testing only. There are reports of even NEW flexes being bad. So you have to keep known good flexes on hand at all times, so you don't waste your time troubleshooting with possibly bad flexes.
Bad or damaged flex
Low quality aftermarket flex
Other flex cables that are Liquid Damaged
Please note: You MUST have the required flex cables, (Charging port flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
