Xbox Series S
The Xbox Series S hasn't shown many signs of failure as of yet, with the exception of an intermittent shutdown on some consoles, which seems to work fine after a reboot. That said, this page will be updated as and when issues are found.
Known Problems And Solutions[edit | edit source]
Problem | Solution |
No power, no beep |
No video output |
HDMI Ports Now Available![edit | edit source]
HDMI ports are now available for this console on Aliexpress. The ports appear to be reliable and well made, and should be a trustworthy part to keep in your inventory.
Standby Voltages[edit | edit source]
This is a work in progress, but here's an ultra high resolution (108megapixel) image of the Xbox Series S motherboard, complete with some standby voltages for debugging. More images will come soon, but until I create a breakout cable the half of the board that is covered by the power supply cannot be accessed, so there's not a lot of test points which can be accessed for probing.
Diode Readings[edit | edit source]
I've obtained diode readings for the HDMI circuit, including the ESD boost protection IC which is another common failure point on games consoles such as the Xbox One S and X. These diode readings should allow simple diagnosis of key components on the HDMI circuit to aide in repair.
Credit[edit | edit source]
TheCod3r
