Xbox 360
This page applies to the Phat (Xenon, Zephyr, Falcon, Jasper) and Slim (Trinity, Corona, Winchester) models. The Xbox 360 uses a grid layout system with letters and numbers to identify parts. For example, U4D1, the GPU, is an IC in section 4D. See the edges of the board for the sections, they are printed on.
No Power[edit | edit source]
Board is unresponsive to power button
Red Ring of Death[edit | edit source]
Ring of light quadrants flashing red/center light red
- To diagnose, hold down the sync button and press eject 4 times
- Each time you press eject, a certain number of the quadrants of the ring will flash
- 4 lights signify 0
- 1 lights signify 1
- 2 lights signify 2
- 3 lights signify 3
- On Xbox 360 E consoles, the ring will flash an amount of times then pause, count these to get the numbers
- After pressing it 4 times, you will have the secondary error code
- Example: seeing 4 lights 3 times, followed by 1 light once, means you have error code: 0001
System Management Controller (SMC) Errors[edit | edit source]
Error Code | Name | Explanation | Possible Repair Actions |
0001 | ERROR_V_12P0 | ANA_V12P0_PWRGD negated unexpectedly | Replace Power Supply, Test and replace MOSFETs, caps, and controller chip on V_12P0 rail |
0002 | ERROR_V_CPUCORE | VREG_CPU_PWRGD negated unexpectedly | Replace Power Supply, Test and replace MOSFETs, caps, and controller chip on V_CPUCORE rail |
0003 | ERROR_V_GPUCORE | VREG_GPU_PWRGD negated unexpectedly | Replace Power Supply, Test and replace MOSFETs, caps, and controller chip on V_GPUCORE rail |
0010 | ERROR_NO_HANA/ERROR_NO_ANA | HANA/ANA is not responding to reads or writes | Replace HANA/ANA or Southbridge |
0011 | ERROR_THERMAL_CPU | CPU temperature overload | Detailed Diagnostic/Repair Actions |
0012 | ERROR_THERMAL_GPU | GPU temperature overload | Detailed Diagnostic/Repair Actions |
0013 | ERROR_THERMAL_EDRAM | eDRAM temperature overload | Detailed Diagnostic/Repair Actions |
0020 | ERROR_GPU_RST_DONE | GPU_RST_DONE signal missing after seqUnReset time passed | Detailed Diagnostic/Repair Actions |
0021 | ERROR_NO_PCIE | PCIE link did not enter L0 after seqUnReset time passed | Detailed Diagnostic/Repair Actions |
0022 | ERROR_NO_HANDSHAKE | CPU did not send GetPowerUpCause to SMC | Detailed Diagnostic/Repair Actions |
0023 | ERROR_NO_CLOCKCHIP | Xenon: ANA_BCKUP is not responding to reads or writes Others: Unknown error related to clock chip | Xenon: Replace ANA_BCKUP, ANA, or Southbridge
Zephyr, Falcon, Jasper: Replace HANA Trinity: Replace C4E3 cap, replace HANA Corona: Replace C4E3 cap, replace Southbridge |
0030 | ERROR_NO_TEMPERATURES | HANA/ANA temperature registers read as zero | Check for shorted resistors, replace HANA/ANA |
0031 | Unknown | V_3P0 and V_5P0 related | Check V_3P0 and V_5P0 circuits, and all its resistors, capacitors, and other parts |
0032 | Unknown | V_CPUVCS related | Check V_CPUVCS circuit, and all its resistors, capacitors, and other parts |
0033 | Unknown | V_MEM related | Check V_MEM circuit, and all its resistors, capacitors, and other parts |
Xbox System Software (XSS) Errors[edit | edit source]
0100 E 16 |
ERROR_NBINIT_MEM_VENDOR_ID | RAM Vendor ID wrong, or not detected | Replace GPU or RAM |
0101 E 17 |
ERROR_NBINIT_MEM_READ_STROBE_DATA_WRITE | Could not write data for RAM read strobe training | Replace GPU or RAM |
0102 E 18 |
ERROR_NBINIT_MEM_READ_STROBE_DELAY_TRAINING | Memory read strobe delay training failed | Replace GPU or RAM |
0103 E 19 |
ERROR_NBINIT_MEM_WRITE_STROBE_DELAY_TRAINING | Memory write strobe delay training failed | Replace GPU or RAM |
0110 E 20 |
ERROR_MEMORY_ADDRESSING | Memory address line failed or unresponsive | Replace GPU or RAM |
0111 E 21 |
ERROR_MEMORY_DATA | Memory data line failed or unresponsive | Replace GPU or RAM |
0300 E 48 |
ERROR_MFG_COMM_FAILURE | Unknown | Unknown |
0301 E 49 |
ERROR_MFG_UNABLE_TO_CONNECT | Unknown | Unknown |
0302 E 50 |
ERROR_MFG_CONNECTX_FAILURE | Unknown | Unknown |
0303 E 51 |
ERROR_MFG_GATEWAY_ERROR | Unknown | Unknown |
0310 E 52 |
ERROR_MFG_BAD_RESPONSE_DATA | Unknown | Unknown |
0311 E 53 |
ERROR_MFG_CHALLENGE_REFUSED | Unknown | Unknown |
0312 E 54 |
ERROR_MFG_BAD_VAULT | Unknown | Unknown |
0313 | ERROR_XSS_MANUF_TEST | Manually triggered error code | Unknown |
1000 E 64 |
ERROR_XSS_CDROM_TIMED_OUT | Kernel DVD drive communications timed out | Replace SATA cable to DVD drive, replace DVD drive PCB, replace Southbridge |
1001 E 65 |
ERROR_XSS_CDROM_NOT_DMA_CONFIGURED | Kernel could not configure DVD drive for DMA mode | Replace SATA cable to DVD drive, replace DVD drive PCB, replace Southbridge |
1002 E 66 |
ERROR_XSS_CDROM_COULD_NOT_CREATE_DEVICE | Kernel could not create DVD drive instance | Replace SATA cable to DVD drive, replace DVD drive PCB, replace Southbridge |
1003 E 67 |
ERROR_XSS_HDD_TIMED_OUT | Kernel HDD communications timed out | Replace HDD, replace HDD port/cable, replace Southbridge |
1010 E 68 |
ERROR_XSS_HDD_NOT_DMA_CONFIGURED | Kernel could not configure HDD for DMA mode | Replace HDD, replace HDD port/cable, replace Southbridge |
1011 E 69 |
ERROR_XSS_HDD_COULD_NOT_CREATE_DEVICE | Kernel could not create HDD instance | Replace HDD, replace HDD port/cable, replace Southbridge |
1012 E 70 |
ERROR_XSS_HDD_NOT_FOUND | Kernel couldn't find HDD Note: This error does not show up because a HDD is missing, it shows up when a HDD is detected, but can't be found | Replace HDD, replace HDD port/cable, replace Southbridge |
1013 E 71 |
ERROR_XSS_XAM_NO_DASH | XAM could not find dash.xex on flash | Unplug HDD, if error clears, format or replace HDD, else Rebuild and reflash NAND |
1020 E 72 |
ERROR_SMC_FLASH_CONFIG_CORRUPT | SMC configuration corrupt | Rebuild and reflash NAND |
1021 E 73 |
ERROR_HSIO_TRAINING_FAILED | GPU to eDRAM High Speed Link failed, eDRAM faulty or unresponsive | Replace GPU |
1022 E 74 |
ERROR_HSIO_CALIBRATION_FAILED | GPU to eDRAM High Speed Link failed, eDRAM faulty or unresponsive | Replace GPU |
1023 E 75 |
ERROR_UNEXPECTED_ETHERNET_PHY_VENDOR | Southbridge could not communicate with Ethernet PHY over MDIO/MDC | Replace Ethernet chip, replace Southbridge |
1030 E 76 |
ERROR_ETHERNET_PHY_RESET_FAIL | Ethernet PHY failed to reset correctly or complete reset | Replace Ethernet chip |
1031 E 77 |
ERROR_ETHERNET_PHY_READ_WRITE_FAIL | Could not read or write to Ethernet PHY | Replace Ethernet chip |
1032 E 78 |
ERROR_UNSUPPORTED_GPU | GPU is down revision, not supported on this board | Replace GPU with correct revision for board |
1033 E 79 |
ERROR_XSS_FLASH_NO_XAM | xam.xex not found on flash | Unplug HDD, if error clears, format or replace HDD, else Rebuild and reflash NAND |
1100 E 80 |
Unknown | NAND LDV does not match eFUSE | Rebuild NAND with correct LDV Phat: Check value of R6T3 resistor |
1101 E 81 |
Unknown | Unknown/Update related? | Unknown/Rebuild NAND? |
1102 E 82 |
Unknown | Unknown/eDRAM/HSIO related? | Unknown/Replace GPU? |
Capacitor Plague[edit | edit source]
Many Xbox 360 units are affected by capacitor plague. However, most systems do not contain these defective caps. These caps are likely to fail:
- Sanyo WF series (most common)
- Nichicon HM and HN series
- Rubycon MFZ series
Replace affected capacitors with Low ESR or Ultra-Low ESR capacitors that have the same capacitance(uF), Voltage(V), temperature rating(e.g. 105°C), and dimensions(mm).
Credit[edit source]
Original article credit: Octal450
