| Sony WH-1000XM4 Headphones Won't Charge Above 10% Repair | |
| Device | WH-1000XM4 |
| Affects part(s) | SUB_R board |
| Needs equipment | Screwdriver, pry tool |
| Type | Part replacement |
How to repair Sony WH-1000XM4 headphones that won't fully charge the battery.
- Headphones won't charge past 10%
Replace SUB_R board (aka right side board / the PCB in the right speaker assembly.) This is one of the most common issues with the WH-1000XM4.
