Sony Dualshock 4 not connecting/charging through USB
Device Sony Dualshock 4
Affects part(s)
Needs equipment
Difficulty ◉◌◌◌ Easy
Type
Controller not connecting/charging through USB
  • Does not charge
  • Does not sync with a console
  • Check USB port
  • If controller has been opened, check ribbon cable/connector for damage
  • Check for open fuse (charging) / shorted USB data (D+/D-) protection component (communication) on USB-connector board
*This guide was imported from the old wiki.
