Sony Dualshock 4 Taking 3.4+ amps rather than 3 amps
Device Sony Dualshock 4
Affects part(s)
Needs equipment
Difficulty ◉◌◌◌ Easy
Type
Device does not turn on
  • Taking 3.4+ amps rather than 3 amps
  • You have the wrong ribbon cable plugged in; there are 10, 12, and 14 pin ribbon cables depending on your controller version. Google the charger's name (e.g. JDS-030 or JDS-011) and find out how many pins you need. Either solder a wire to every connection or buy a new ribbon cable
*This guide was imported from the old wiki.
