Sony Bravia KDL-40W2000 screen does not power on and red status light flashes 3 times
Device Sony Bravia KDL-40W2000
Affects part(s) Logic Board
KDL-40W2000 screen does not power on, red light flashes 3 times.
Fuse F7000 blown after 13 years of operation.
  • Screen does not power on.
  • Red light flashes 3 times.
There's a DC issue on the main board (P/N : 1-871-229-12) maybe due to a blown fuse called F7000. You should also check fuse PS7000 right next to it. Make sure that there's no short to ground before replacing the fuse.
