PlayStation 4 Not turning on repair | |
Device | Playstation 4 |
Affects part(s) | Motherboard, Power supply |
Type |
Diagnosing and fixing issues related to "No power" on a PS4
- Not turning on
Check power supply is outputting +5V_STBY at PSU Connector on board
Check power supply is outputting 12v at PSU Connector on board
Check for shorts around the southbridge IC
Check for Blow Fuses
