We will be continuing maintenance on the wiki starting this Saturday at 9 am (UTC) to Sunday at 7PM (UTC).
There is a possibility of long maintenance-breaks and downtime during this time.
For more information contact us in the wiki Discord or by email at: unto@fighttorepair.org
PS4 UART Guide
This is a guide for diagnosing pulsing blue light of death (BLOD) on the PS4.
Tools you will need:[edit | edit source]
- A programmer to dump the flash (I use CH341A for example)
- Proper adapter for the bios chip (see below)
- Programmer Software (I use AsProgrammer)
- Serial monitoring software (I use Putty)
- A USB to TTL 3.3v converter (I use CH341A)
- Some insulated wire (needs to be thick enough)
- Hex Editing Software (I use HxD)
- Soldering Iron
- Hot air station
- Solder
- Flux
Starting Up[edit | edit source]
BwE has provided a 'UART & Programmer Collection' pack which will aid in this project. It contains all of the following:
- CH341A Programming Software
- AsProgrammer 2.03a
- SkyGz CH341A Mini Programmer Black Edition 1.18
- NeoProgrammer 2.2.0.8
- Modified SkyGz CH341 Programmer v1.1.1.25 by Kovzhun Mikkhail Alexandrovich (English/Russian)
- CH341A Drivers
- Logic Analyzer Software
- Pulseview
- Zadig (USB Driver)
- PuTTY
- USB TTL Drivers
- FT232
- PL2303
Depending on the USB TTL device you have you need to install the drivers for it. If you are not using the above pack, download the appropriate driver below. PL2303 is not recommended.
Dumping/Patching[edit | edit source]
Desolder your NOR chip from the board, if you do not know where that is or how to do it I suggest you discontinue this adventure early.
Next is to solder the chip to a breakout board, as seen below.
If you have a SOIC chip (it has little legs) then soldering is quite easy, just use heat.
If you have a WSON chip (the legs are not exposed, as pictured below) then you must mask off the ground pad with something non-conductive and heat resistant. I used kapton tape.
Once it is on the breakout board, read the chip with whatever you have chosen to program it with. Teensy using NORWay or a CH341A for example.
Using the aforementioned software (Or nothing if using NORWay) dump the NOR at least twice and compare the MD5 of each dump, you can use HxD or some other tool to do this. Generally if you have desoldered the NOR and put it on a breakout board there is minimal chance for failure.
Next, using the ps4-wee-tools, patch the NOR for UART. You may also try lowering the GDDR5 clock to 1000MHz. This may fix some DCT errors.
Writing[edit | edit source]
Using the same software you used to dump the NOR start by erasing it entirely and then writing your patched dump. Erasing it seems to fix a few issues that may cause the BLOD in PS4's (and even some issues in the PS5). This makes the whole process longer, but it is worth it.
Once this is done, remove the NOR chip from the breakout board and put it back on the console the way you found it. Ensure everything is clean and well presented.
Soldering UART Pins[edit | edit source]
The only 2 pins you will need to solder is Ground, and TX. Before you start, ensure that the TX pin on your PS4 is indeed getting 3.3v on start up.
If your USB TTL has jumpers, ensure that it is set to 3.3v.
Attach or solder the ground and TX lines to the USB TTL and plug it into your computer. Do not use cable that is too thick or too thin. I generally just use jumper wires as they are easy to plug into the USB TTL device.
Assembly[edit | edit source]
If you want to keep this permanent, ensure that your cables are long enough and you are able to route to the USB TTL while the case is closed.
Make sure the pins are insulated when reassembling the console. Make sure there is no force on the wires.
You can also choose to not re-assemble the console, just ensure that you have a heatsink on top of the APU and power it correctly.
Serial Monitor (Actually reading the UART)[edit | edit source]
If you want to be fancy you can use a cheap USB Logic Analyzer to view the UART output, but this is a bit much for beginners.
I suggest using PuTTY to read the UART output: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Run PuTTY and select Serial, input the correct COM port in the serial line (You can find out what yours is within WIndows Device Manager under Ports (COM & LPT)). In speed put in 115200 which is the baud rate for the PS4 UART.
Now hit OPEN and move on to the next step!
Diagnostic[edit | edit source]
- Turn on the console.
- Whatever the UART output stops at is the issue.
Common Errors[edit | edit source]
ERROR:DCT[0/1] is disabled[edit | edit source]
The first ram block has a failure. A ram block is a pair of ram modules. It will complain about both of them, even when only one is failing. The ram blocks are 0/1, 2/3, 4/5, 6/7
ERROR: main(####) loadBios -8[edit | edit source]
Accompanied with ERROR: loadBios(####) sceSblSlLoadSelf -8, ####
Your syscon is not decrypting the CoreOS in both errors.
Solution: Replace all per-console chips with that from a donor board. Essentially get an entirely new working or partially working console and use it for parts.
Best Solution: Swap active CoreOS with inactive, you need to patch the NOR and Syscon in order to facilitate this. https://www.youtube.com/watch?v=hcmMSYmwSUQ
https://www.betterwayelectronics.com.au/#ps4sales
https://betterwayelectronics.com.au/sce_syscon.html
SAMU Enter/Leave[edit | edit source]
Loops the message SAMU Enter and SAMU Leave.
SAMU is responsible for managing keys and decryption.
APU is likely the cause, no definitive fix.
IDPS Error[edit | edit source]
Console is a brick, place it gently in the bin or strip it entirely for parts. Unfixable.
Panic EAP Key Not Available[edit | edit source]
Fixable with BwE PS4 NOR Validator. https://www.betterwayelectronics.com.au/#ps4sales
Example Outputs[edit | edit source]
- LoadBios: https://pastebin.com/4rgJA5pb
- SAMU Enter/Leave: https://pastebin.com/h6aqUnKv
