MacBook Pro A2289 No post, boot, or image with initial fan spin, drawing 0.2A at 20V repair
Device MacBook Pro A2289
Affects part(s) Motherboard, Camera, Display assembly
820-01987 MacBook fan spinning initially but not posting, booting, or showing an image.
  • Drawing 0.2A at 20V as measured with a USB-C meter
  • No picture
  • Initial fan spin
Dead U7710/U8110
  • This is a signature fault on the 820-01598 and 820-01987 logic boards.
    • The VCCIO (U8110) and EDRAM (U7710) buck converter controller ICs fail in unison, resulting in a no POST/boot condition.
    • You will often observe that the fan spins briefly and the amperage (as measured on the USB C amp meter) will settle around 200ma (0.2A)
  • Measure PP0v95_S0_CPUVCCIO_REG_R on L8102.
    • If voltage is present, this is not your issue.
    • Measure the PVCCIO_EN signal at R8165, It should be present at 3.3v.
    • Measure the PPVCCEDRAMS0_EN_FILT_BUF signal at R7766 - It should be present at 3.3v
    • If any of those is missing, proceed to the repair steps below.
  • If both enable signals are present, and PP0v95_S0_CPUVCCIO_REG_R is missing, replace BOTH U7710 and U8110.
  • Typically, when this fault occurs, you will have either no backlight or no camera function after the repair.
    • It is unknown why this happens, however it probably is related to either the backlight driver serial communication or camera serial communication somehow overloading parts of the CPU, causing it to draw more power than the chips are rated for causing this issue.
    • If the device has no backlight after the repair:- Replace U8400
  • If the device has no camera function after the repair:- Replace the display assembly
