We will be continuing maintenance on the wiki starting this Saturday at 9 am (UTC) to Sunday at 7PM (UTC).
There is a possibility of long maintenance-breaks and downtime during this time.
For more information contact us in the wiki Discord or by email at: unto@fighttorepair.org
MacBook Pro A2251 no camera detected repair
Jump to navigation
Jump to search
This article is a stub. You can help Repair Wiki grow by expanding it. |
MacBook Pro A2251 no camera detected repair | |
Device | MacBook Pro A2251 |
Affects part(s) | Motherboard, Display Assembly |
Needs equipment | multimeter |
Difficulty | 3. Hard |
Type | Micro-Soldering, Soldering |
Problem description[edit | edit source]
Addressing issues with a MacBook (820-01949) not detecting the camera.
Symptoms[edit | edit source]
- Camera not detected
- Possible burned or exploded L8504 filter on TCON board
Solution[edit | edit source]
Identifying the problem[edit | edit source]
Check L8504 Continuity:[edit | edit source]
- Use a multimeter in continuity mode to check L8504 (Figure 1).
- If L8504 is blown or burned, proceed to the "L8504 blown or visibly burned repair steps" below.
Test with Known Good Display:[edit | edit source]
- Make sure to check L8504 before diagnosing the display issue.
Solving the problem[edit | edit source]
Camera Works with Known Good Display:[edit | edit source]
- If camera works with a known good test display, replace the display assembly.
L8504 Blown or Visibly Burned:[edit | edit source]
- Understand that L8504 failure indicates a catastrophic short within the TCON board of the display or a melted/corroded display cable/connector.
- Repair L8504 only after addressing the display issue, as L8504 might fail again if the display issue persists.
- When replacing L8504, address corresponding pad and trace damage.
- Connect jumper wire from the input side of the filter (PP5v_G3S) to R5610 (Figure 2) or a suitable point.
- After replacing L8504 and addressing trace issues, replace the display assembly or repair it by replacing damaged cables/connectors.
No Camera Function, L8504 Normal:[edit | edit source]
- If no camera function after firmware revive, and other causes are ruled out, U8504 might be faulty, or there could be trace/resistor issues between the camera connector/U8504 or between U8504 and the T2 chip.
