| MacBook Pro A2159 Touchbar brightly flashes following shut down or login repair | |
| Device | MacBook Pro A2159 |
When the touchbar flashes after shutdown or login, this will be related to corrupted BridgeOS firmware and will be resolved via a DFU revive or restore.
- Flashing touchbar
DFU Revive or restore BridgeOS
- Ensure you're running the latest macOS version for consistent results.
- Follow the provided Apple support article for the procedure, including on how to force a Intel based MacBook into DFU mode by using a key combination.
- Solder a wire across SE032 (Omitted/No Stuff) to pull SOC_FORCE_DFU high. Wire should be across pins 3 and 4 or 1 and 2.
- SELECTING RESTORE WILL WIPE ALL USER DATA!
- If a DFU Revive or Restore does not resolve the issue, try placing the board in a known good top case or replace the touchbar/top case.
If the issue still is not resolved after touchbar replacement, the issue is likely related to the T2 chip's internal GPU and cannot be repaired without replacing the system board, or replacing the T2 chip. (Not recommended.)
