MacBook Pro A2141 No backlight on display repair | |
Device | MacBook Pro A2141 |
Identifying and solving backlight issues on the 820-01700 logic board, as well as similar boards from 2016-2020. A MacBook Pro with no backlight on the display is experiencing an issue where the screen remains dark even though the computer is powered on and operational. This means that while the computer itself may be functioning, the display is not emitting any light, making it extremely difficult or impossible to see the content on the screen. Shining a strong light on the display at an angle might reveal that the content is indeed present, but the backlight is not illuminating it.
Diode mode readings that are important for diagnosis:
PPVOUT_S0_LCDBKLT_F: ~1.180
PPVIN_SW_LCDBKLT_SW: ~0.830
PP5V_S0SW_LCD: ~0.570
PP5V_G3S_BKLT_D: 0.410
PP5V_G3S_BKLT_A: ~4.10
- C8471 or adjacent capacitors in the series is an appropriate area to measure, since it does not require removal of the system board.
Check U8400 and its circuit
