MacBook Pro A1990 Not turning on, drawing 0.00A - 0.02A at 20V repair
Device MacBook Pro A1990
Affects part(s) T2 firmware
Needs equipment None
Difficulty ◉◌◌◌ Easy
Type Software
A1990 MacBook not turning on, drawing 0.00A - 0.02A at 20V, PP3V3_G3H_SOCPMU present, but PPVCCPRIMCORE_PRIM_REG and therefore PP3V3_S5 missing.
  • Not powering on
  • Missing PP3V3_S5 and PPVCCPRIMCORE_PRIM_REG voltages
  • Only drawing 0.00A - 0.02A at 20V as measured by USB-C meter
Do not replace U7800. Instead, put device into DFU mode and select advanced -> repair. Read this apple article.
The problem seems to be T2 not talking to the PMU correctly. Note, you need a battery connected for PMU to work. Best to completely assemble the device.
The 2019 16" model has the same issue.
