MacBook Pro A1707 Not charging repair | |
Device | MacBook Pro A1707 |
Affects part(s) | Charger |
Needs equipment | None |
Difficulty | ◉◌◌◌ Easy |
Type | Software |
Fixing an issue with A1707 TouchBar MacBook Pro that is not charging properly.
- Discharge during normal operation
- Won't charge during normal operation when plugging in charger
- Won't charge when turned off
Charger may have gone on strike. Unplug charger from AC and from Laptop, wait a few seconds, try again. Try a different port on MacBook (the problem with the other port will go away automatically).
SMC problems may prevent charging at all. When turned off, perform an SMC reset
