| MacBook Pro A1706 PP3V3 G3H short repair | |
| Device | MacBook Pro A1706 |
Missing PP3V3_G3H on A1706 MacBook Pro
- MacBook not turning on.
- Not charging
- A CD3215 is short circuited to ground, will show up instantly on thermal camera which one it is.
- CB300 corroded, but you can't see it because it is hiding under the metal around the NAND. LOOK CLOSELY!
- Some other random component, but check CB300 first.
