| MacBook Pro A1706 Charger not turning on USB-C meter repair | |
| Device | MacBook Pro A1706 |
When charging the A1706 MacBook with a USB-C charger and measuring the input current and voltage with a USB-C meter, the meter does not even turn on at all or 0 current.
- MacBook not turning on.
- All voltages missing.
- Not charging.
Check PP20V_USBC and PPDCIN_G3H resistance
- Measure the resistance between PP20V_USBC and GND with a multimeter on resistance mode
- if you read less than 50 ohms, you have a short, proceed to "Short on PP20V_USBC or PPDCIN_G3H" repair steps below
- Measure the resistance between PPDCIN_G3H and GND with a multimeter on resistance mode
Faulty USB-C port
If both rails above are not shorted, it is highly likely that the USB-C port itself is shorted or damaged inside.
- Inject 1V to the shorted rail using a Lab Bench Power Supply.
- With a thermal camera, identify the source of the short, most likely it is a capacitor
- Replace the shorted component.
Shorted USB-C port
Replace the offending port.
