MacBook Pro A1706 Battery not recognized repair | |
Device | MacBook Pro A1706 |
Affects part(s) | Motherboard, battery |
MacBook A1706 not recognizing the connected battery
- MacBook not turning on.
- Battery not recognized/charging
- First, try a known good battery.
- If it doesn't work, check the battery cable going to the board.
- Sometimes there is corrosion here, sometimes the customer tore the bar on the connector off the connector.
- In some rare cases the SMC still is a factor in battery recognition on this board.
