| MacBook Pro A1502 2015-2016 Not turning on (only 120 mA current draw) repair | |
| Affects part(s) | Whole board |
| Needs equipment | Screwdriver set, tweezers |
| Difficulty | ◉◉◌◌ Medium |
| Type | Part replacement |
#incomplete
- Not turning on.
- Pulling 120 mA from the charge port.
Cause:
- Spillage
- Corrosion on keyboard backlight connector
- Short to ground via keyboard backlight connector
Fixed by removing keyboard backlight connector. Replace with new keyboard backlight connector.
