| MacBook Air A1466 Not turning on, damaged JTAG connector repair | |
| Device | MacBook Air A1466 |
This article is aimed for a not turning on MacBook Air A1466 that has a corroded/damaged JTAG connector
- Not turning on
JTAG connector (even if unused) that is corroded or damaged can cause several problems or help you figure out the problem. Connector must be replaced/removed and the area must be cleaned.
Example video where three A1466 MacBook Air machines did not have a green light on the charger caused by corroded JTAG connectors.
Good method for removal of JTAG connector
You can buy them from here
