IPhone XR Stuck in DFU, updates successfully but goes back to DFU
Device IPhone XR
Affects part(s) Motherboard
Needs equipment
Stuck in DFU mode
Flashes successfully with an update or restore but goes back to DFU mode.
  • Screen shows no image and pulls 0.45A via USB charging
  • Does not appear to boot
  • Prompt to boot on DCPS, shows it hangs around 45mA draw
  • Connect to PC and it's in DFU mode
  • Flash an update or restore & it goes through 100% with no errors but goes back to DFU mode
  • Check R0601 at the corner of NAND.
  • This resistor connects PP1V8_IO to SPI_AP_TO_S4E_MOSI_BOOT_CONFIG1
  • Clean the underfill around it & poke it hard.
  • If it breaks, it must be replaced.
  • Value is 4.7ohms
  • After replacing it, the phone will no longer be in DFU mode & boot right up.
Migrated from old wiki
