| IPhone Upper-Layer Compatibility Guide (Sandwich Logic Boards) | |
| Type | |
| Device(s) | |
| Difficulty | |
What Is the “Upper Layer”?
On modern iPhones with sandwich (two-layer) logic boards, the board is split into:
- Upper layer – CPU, NAND, Logic EEPROM
- Lower layer – Baseband, WiFi and NFC (in some models)
An upper-layer swap means transferring the entire top board from one device to another, usually to recover data or restore functionality when the upper layer is damaged.
Compatibility by iPhone Generation
| iPhone Generation | Models in Generation | Upper Layer Swap Compatibility | BOARD ID RESISTOR |
| iPhone X Series | X | ✅ Same model only | |
| XS | ⚠️ Compatible only with XS (PMIC-specific) | ||
| XS Max | ⚠️ Compatible only with XS Max (PMIC-specific) | ||
| iPhone 11 Series | 11 | ✅ Same model only | |
| 11 Pro | ✅ Compatible with 11 Pro Max (Board ID mod required) | ||
| 11 Pro Max | ✅ Compatible with 11 Pro (Board ID mod required) | ||
| iPhone 12 Series | 12 | ✅ Same model only | |
| 12 Mini | ✅ Same model only | ||
| 12 Pro | ✅ Same model only | ||
| 12 Pro Max | ✅ Same model only | ||
| iPhone 13 Series | 13 | ✅ Same model only | |
| 13 Mini | ✅ Same model only | ||
| 13 Pro | ✅ Same model only | ||
| 13 Pro Max | ✅ Same model only | ||
| iPhone 14 Series | 14 | ✅ Compatible with 14 Plus (Board ID mod required) | |
| 14 Plus | ✅ Compatible with 14 (Board ID mod required) | ||
| 14 Pro | ✅ Compatible with 14 Pro Max (Board ID mod required) | ||
| 14 Pro Max | ✅ Compatible with 14 Pro (Board ID mod required) | ||
| iPhone 15 Series | 15 | ✅ Compatible with 15 Plus (Board ID mod required) | |
| 15 Plus | ✅ Compatible with 15 (Board ID mod required) | ||
| 15 Pro | ✅ Compatible with 15 Pro Max (Board ID mod required) | ||
| 15 Pro Max | ✅ Compatible with 15 Pro (Board ID mod required) | ||
| iPhone 16 Series | 16 | ||
| 16 Plus | |||
| 16 Pro | ✅ Compatible with 16 Pro Max (Board ID mod required) | ||
| 16 Pro Max | ✅ Compatible with 16 Pro (Board ID mod required) | ||
| iPhone 17 Series | 17 | ||
| 17 Pro | ✅ Compatible with 17 Pro Max (Board ID mod required) | ||
| 17 Pro Max | ✅ Compatible with 17 Pro (Board ID mod required) |
