| IPhone 6 Plus | |
| Manufacturer | Apple |
| Code name | A1522, A1524, A1593 |
| Release date | 2014-09-19 |
| Device type | Phone |
| Parts that are serialized on iPhones | Troubleshooting/Diagnostics |
| IPhone 6 Plus Boots to recovery mode iTunes Error 9 | Motherboard | Soldering | 4. Specialist |
| IPhone 6 Plus Touch Disease | Motherboard | Soldering | 3. Hard |
iPhone 6 Plus display connector. Top right goes to top of the board, under the rear camera.
iPhone 6 Plus touch connector. Top right goes to top of the board, under the camera.
iPhone 6 Plus charge port / dock flex connector. Bottom left goes to edge of the board, next to bottom of the battery.
iPhone 6 Plus home button connector. Top left corner goes to top right of the board, under the rear camera.
iPhone 6 Plus rear camera connector. Top right goes to top of the board, under the rear camera
iPhone 6 Plus front camera, proximity sensor, ambient light sensor, earspeaker connector. Top right goes to top edge of the board, under the rear camera.
Cumulus Diode Values
Meson Diode Values
Tristar Diode Values
Home Button Diode Values
iPhone 6 Plus Schematics: https://www.sendspace.com/file/9mqiqf
