IPad 10.2in 8th Gen Not turning on, drawing between 0-0.2A, tristar is functional repair
| IPad 10.2in 8th Gen Not turning on, drawing between 0-0.2A, tristar is functional repair | |
| Device | IPad 8 |
| Affects part(s) | Main Logic Board, PMIC |
Solving an issue where the iPad 10.2in 8th gen would not turn on, cycles power draw from 0A to 0.300A then the screen would flash and cycle again and the Tristar is working as intended.
- Flashing screen
- Cycling power draw (0-0.3A)
This specific problem was caused by bad PMIC failing to output GPIO_PMU_TO_LCD_PWREN.
Replacing PMIC solved the issue.
