| Hum or rev noise when running vehicle | |
| Device | 2002 ES300 |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
When listening from outside vehicle noise not herd. Inside vehicle noise is herd from body.
Possible areas of Problem:
- Possible areas of problem: With stethoscope listen to fuel pressure damper set (on fuel rail). If pulsation is herd suspect damper
Fuel Pressure Pulsation Damper Assy was the problem
Replace Fuel Pressure Pulsation Damper
