| How to fix an iPad Air that shows the low battery screen but will not charge | |
| Device | IPad Air |
| Affects part(s) | battery |
| Needs equipment | pry tools, screwdriver, heat mat / heat gun |
| Difficulty | ◉◉◌◌ Medium |
| Type | Part replacement |
Fixing an issue where the iPad responds to a charger being plugged in by showing the low battery screen but will not actually charge the battery
- Battery is too low to power on the iPad.
- Screen goes blank as soon as the charger is disconnected.
This is most commonly caused by an old or defective battery that needs to be replaced.
