How to fix IdeaPad Yoga 13ALC6 not turning on, with 15V on USB-C and red flashing LED
| How to fix IdeaPad Yoga 13ALC6 not turning on, with 15V on USB-C and red flashing LED | |
| Device | IdeaPad Yoga 13ALC6 |
| Affects part(s) | Charge port |
Lenovo IdeaPad Yoga 13ALC6 faces a critical issue of not powering on, accompanied by a red flashing indicator, displaying 15V and 0.00A on the USB-C meter.
- Red flashing light
- Drawing no current at 15V from the charging port
- Sometimes charging, sometimes not
Check USB-C 5v pins
The laptop might charge occasionally but will not power on. Despite most of the board seeming fine via multimeter, this is usually caused by the charging USB-C port (The secondary USB-C on the right does not provide power.) The blinking light indicates power fluctuation, fix by replacing the port.
