How To Fix iPhone 4S With Short Battery Life | |
Device | |
Affects part(s) | |
Needs equipment | |
Difficulty | |
Type |
Short battery life (instant death, irregular charge time, ect.)
![](/images/thumb/3/30/Placeholder_image.jpg/300px-Placeholder_image.jpg)
- Short battery life
- instant death
- irregular charge time
- & other similar behavior
This is often caused by a bad battery.
- Test another battery
- - Remove the two P2 Screws at the bottom of the phone - push the back glass up towards the top of the phone. pull off glass gently.
- - remove the two Philips 00 screws holding the battery connector on, (pay attention to placement of these screws)
- - carefully remove pressure contact
- - unclip battery connector
- - pull battery tag ( if no tag, use 99% alcohol under the battery)
- - place new battery, reassemble
