| How To Fix an iPad Pro 10.5 That Is Boot Looping or Stuck on the Apple Logo | |
| Device | IPad Pro 10.5 |
| Affects part(s) | motherboard |
| Needs equipment | |
| Type | Soldering, Teardown, Part replacement |
When turning on the iPad the Apple logo appears on the screen but the device will not fully boot. It may stay on the Apple logo permanently or restart itself after a short time.
- Boot looping, only displaying the Apple logo
- Never gets to the lock screen
Disconnect all flex cables. This can often be caused by the headphone jack extension flex cable becoming damaged after a drop. Also check for loose or broken coils around the power management IC on the logic board.
