Fatshark Sharkbyte HDZero | |
Manufacturer | HDZero |
Code name | |
Release date | |
Device type | Drone |
This module was the first model released under the Shark Byte brand using HD Zero chipset and is compatible with all VTX modules by both HDZero and Fat Shark.
- Model RX5.1
- Weight:80.3g
- Dimensions:105 x 21 x 39mm
- Operating Frequencies:5.725-5.850GHz
- Input Power: 5.5mm Barrel Connector, 8-16V Center Pin Positive
