| Problem
Solutions
| The printed page is all black (laser)
- In AIO type cartridge unit. check the pins connecting to the AIO cartridge. Ensure they are not dirty or bent.
- Check drum surface not damaged
| The printed page is all white (laser)
- Check laser path not blocked - ex: by a shutter failing to open
- EMPTY toner
- Image transfer belt completely torn apart
| The borders of the printed page are dimmer than the center of the print (laser)
| Black stripe at the side of each printed page (laser)
| Black line on COPIES, not prints (laser)
- Check slit glass - tiny amount of whiteout or ink may be contaminating it.
| After disassembling and reassembling the printer, control panel LEDs blinks randomly
- Check that all ribbon cables are securely and properly connected.
