| Problem
Solutions
| Inkjet printing carriage is stuck at the side of the printer (inkjet)
| Random black spots on color print (inkjet)
- Clean the dry ink under the printing head. If a proper cleaning solution is not available use ammonia-based glass cleaner (i.e. Windex). Do not use isopropyl alcohol.
| After disassembling and reassembling the printer, control panel LEDs blinks randomly
- Check that all ribbon cables are securely connected.
| Printer reports inexistent paper jam (inkjet)
- Clean the round-shaped plastic film that provides rotational info to the encoder.
| Printed characters are blurry (inkjet)
- Clean the long, thin plastic strip that provides longitudinal position information to the encoder.
