ClipperCreek HCS series
(up to EV chargers section)
  • Power / Yellow
  • Charging / Green
  • Power Fault / Red
  • Charging Fault / Red
Background / failure modes
  • broken latch hook (see section below)
  • High ground leakage
A common problem with Level 2 EVSEs in general is that the contactor welds itself closed. Typically not an issue with ClipperCreek though. OpenEVSE chargers like to do this later in life. After taking it apart and filing down the welds on the contact faces, you start just banging your fist on it real hard a couple times. Then power cycling it. That fist induced vibration was usually enough to break those welds, power cycle to clear the error, and get it working again for another month. Before it welded itself again. (will move this to OpenEVSE page later)
Broken latch hook
A common failure is that the latch hook breaks, usually due to a newer user having trouble getting their car to release the plug and thus breaking it off.
Newer Clipper Creek units were equipped with J1772 plug assemblies from Delphi. Someone created a part file for the latch hook for that plug and posted it to Thingiverse here:
https://www.thingiverse.com/thing:7280158
You can download the STL files and 3D print yourself, or use one of the 3D printing services such as Treatstock. They'll just need the STL file, which you'll find in the zip file that you can download for free from Thingiverse. When submitting the order, select ABS plastic, and 50% infill, both to make the part stronger.
To take apart the Delphi J1772 plug, you'll need a Torx T-10 security bit. Here, "security" means there's a central post that the bit has to accommodate, so a regular Torx bit won't work. Undo the 7-8 screws, gently pry that one half of the shell off (leaving the parts nestled in the other half), and swap in the new part.
Relay / contactor information
Hongfa contactor seen in actual unit
Notes:
contactors for HCS series
60mm H x ~80mm L x ~50mm W
coil terminal tabs are splayed
no coil cover
has manual button override
American Zettler XMC0-402.ID data sheet from Zettler DigiKey ($10 for qty 1)
  • same as Zettler above but with "standard thermoset frame" instead of "compact thermo plastic frame"
  • visually looks the same
  • 66mm H x 84mm L x 50mm W
  • manual override exposed
  • coil is covered
  • tested with HCS-40 in Aug 2024, worked fine
Appli Parts APAC-240240 Amazon, $21
  • 65mm H x 82mm L x 55mm W
  • exposed coil
  • testing with HCS-40 in Oct 2024 ...
CGELE UPC ‎774297736354 Amazon, $12 inspected Aug 2024:
  • 65mm H x 88mm L x 53mm W
  • exposed coil
BlueStars LTC-2S-40 / 2P-40A-240V Amazon, $13 inspected Aug 2024:
  • 65mm H x 82mm L x 53mm W
  • exposed coil
Packard C240C unknown
Eaton C25BNF240B specification Ebay, $40+S/H From spec sheet:
  • 59mm H x 81mm L x 50mm W
More product photos
inside view of HCS series EVSe, with back cover removed
lone PCBA inside the HCS series EVSE
