Apple T2 platform | |
Device(s) | Apple Laptops |
Devices using T2 / T8012 SoC
All Intel MacBooks 2018-2020
Mac Pro 2019
iMac 2020, iMac Pro
Mac Mini 2018
Theory
Main functions:
- Encryption processor: T2 has Apple's own security enclave processor (SEP), which is used for encryption, payment verification, authentication, and Touch ID.
Firmware
Power Sequence
- T2-Calpe power stage:
T2 Power diagram
Power Sequence
Please note that sequential list does not mean that having some deeper steps rules out all previous. during diagnostics try go through whole sequence. As an example, PMU_CMK32K_SOC is not required untill T2 fully boots iBSS firmware from Socrom. Howeve it would prevent its SMC Firmware part to initiate further power sequence.
