| Acer Aspire E5-773G Battery is not working repair | |
| Device | Aspire E5-773G |
| Affects part(s) | Battery |
| Needs equipment | None |
| Type | General |
Fixing an issue with an Acer Aspire E5-773G laptop where the battery "does not work"
- Battery not working
- this laptop has an Battery enable switch (SW1) in the lower left corner (view from keyboard side)
- press the switch on startup, or assemble the keyboard case to press it down
