| APC Back-UPS 600VA | |
| Manufacturer | APC |
| Code name | |
| Release date | |
| Device type | Other |
30 AMP FUSE REPLACEMENT
The board has two 30-amp blade-style fuses that may go bad. If the device has a known good battery and has the symptoms of "Replace Battery" per the user guide. To replace the fuse:
- Remove the battery and battery cover
- Remove the 4 Phillips screws
- Remove the back cover
- Disconnect all connectors on the main board and remove the main board.
- Test continuity on each 30-amp fuse.
- Desolder and resolder a new 30-amp blade-style fuse for the one without continuity.
- Place the main board back and reconnect all connectors.
- Return battery wires through labeled openings on the back cover and reinstall.
- Screw in 4 screws.
- Install battery and cover.
- Complete.
Internal Fuse (2x) - 30 Amp Blade Style
Battery - APCRBC110
Product Page: https://www.apc.com/us/en/product/BN600G/apc-backups-600va-120v-8-outlet-retail/
