Steam Deck - Replace shoulder switch R1/L1
Device Steam Deck
Affects part(s) Controller Board rev. B
Needs equipment Soldering Iron, replacement switch
Difficulty ◉◉◌◌ Medium
Type
A common problem with the controller board of the Steam Deck LCD are the shoulder switches, that can break off easily during disassembly.
There are multiple compatible replacement switches. On Aliexpress they are sold as "Steam Deck switch" or "XBOX 360 pair switch".
Those switches have three pins and two legs (the latter for mounting through the pcb).
Test point of the L1 shoulder switch on the rev B controller board - full view
Figure 1: Test point of the L1 shoulder switch on the rev B controller board - full view. Red box: signal multiplexer. green arrow: testing point for the L1 switch.
Swapping of the switches should be self-explanatory.
In case the signal pads on the pcb get damaged:
On each controller board the leftmost and rightmost pin of the switch is connected to the ground plane of the board.
Figure 2: Test point of the L1 shoulder switch on the rev B controller board. red circle: testing point for the L1 switch.
The middle pin is connected to the MCU/a signal multiplexer. On the left controller board you can strip the solder mask of the trace, running to the middle pin of the switch or connect the middle pin of the switch to the corresponding testing point for the L1 switch (see figure 1 and 2).
Figure 3: Test point of the R1 shoulder switch on the rev. B controller board. green circle: testing point for the R1 switch.
On the right controller board, the middle pin is connected to the testing point visualised in figure 3.
