Raspberry Pi Issues Booting or Reading SD Card Repair
Device Raspberry Pi
Affects part(s)
Needs equipment
Difficulty
Type
Raspberry Pi having issues with booting or reading the SD card.
  • Pi 4
  • Maybe other models too
  • The error Failed to open device: 'sdcard' (cmd 371a0010 status 1fff0001) appears in the boot screen.
  • The system fails to read data from the SD card.
  • The system boots only after a weak bending force is exerted on the PCB.
  • The system freezes randomly, or after a weak bending force is exerted on the PCB.
  • Test the SD card in another Pi to make sure that it's actually working
  • Check the condition of the SD card slot. Fix any issues with it, and reflow the solder of the SD card slot.
  • Reflow the solder underneath the CPU using hot air at 350°C / 660°F.
