MacBook Pro A2338 Not Charging, .15A current draw at 20V
Device MacBook Pro A2338
Affects part(s) Logic Board
Needs equipment Hot Air Station, Soldering Iron, Solder Paste, Soldering Wick
MacBook logic board 820-02020 powers on and runs normally from a USB-C power supply and a charged battery but does not charge the battery. The system reports inconsistent power source status, and PPBUS remains at ~12.3V even with the battery disconnected.
Standard USB-C and charging components test normal, and replacing common charging-related ICs does not resolve the issue.
MacBook Pro A2338 - Detecting Battery Normally
MacBook Pro A2338 - Current Consumption
  • Device boots and operates normally
  • Runs from USB-C power supply without battery connected
  • Battery percentage is visible and health data is readable
  • System reports:
    • Power Source: Battery
    • Connected: No
  • Battery does not charge
  • Same behavior with a known-good battery
  • PPBUS_G3H stuck at ~12.3V
  • PPBUS voltage does not drop when battery is disconnected
  • Device does not drain battery while PSU is connected
MacBook Pro A2338 - UD200 IC Location
MacBook Pro A2338 - Normal Battery Health Status
1. Confirm USB-C Input
  • Measure:
    • 20V present at USB-C input
  • Verify adapter negotiation is normal
✅ If 20V is present, USB-C controllers are functioning
2. Verify Battery Detection
  • Confirm:
    • Battery data visible (cycles, health, percentage)
  • Test with a known-good battery
✅ Battery communication OK
3. Measure PPBUS_G3H
  • Measure PPBUS with battery connected
  • Disconnect battery and re-measure
  • Expected behavior: PPBUS_G3H should be between 12.6 V and 13.1 V
❌ Fault confirmed if:
  • PPBUS remains ~12.3V with battery disconnected
4. Eliminate Common Charging Components
If already replaced with no change:
  • CD3217 (both sides)
  • USB-C ROM
  • Charging IC (ISL)
  • Q5265
→ Charging path is not the root cause
5. Interpret the Data
If all of the following are true:
  • USB-C input is correct
  • Battery communication is correct
  • PPBUS does not respond to battery removal
  • Device runs indefinitely on PSU
Then the fault is PPBUS enable/control logic, not charging hardware.
1. Confirm the Fault
  1. Connect USB-C power supply
  2. Measure PPBUS_G3H
    • ~12.2–12.4 V present
  3. Disconnect the battery
  4. Re-measure PPBUS
    • ❌ PPBUS remains ~12.3 V → fault confirmed
2. Eliminate Software Causes
  1. Attempt Revive using Apple Configurator
  2. Attempt Restore (only if data is not required)
No change confirms hardware-level fault
3. Rule Out Common Charging Components
Verify or replace known-good:
  • CD32xx USB-C controllers
  • USB-C ROM
  • Charging IC (ISL)
  • Q5265
If PPBUS behavior remains unchanged, continue — charging path is not the issue.
4. Identify the Root Cause
  • UD200 is responsible for PPBUS control and regulation
  • A faulty UD200 can:
    • Hold PPBUS active at ~12.3 V
    • Prevent battery charging
    • Cause incorrect power-source reporting
5. Replace UD200
  1. Remove logic board
  2. Apply controlled heat and remove UD200 IC
  3. Clean pads and inspect for damage
  4. Install known-good UD200
  5. Inspect joints under microscope
6. Post-Replacement Verification
  1. Reconnect battery
    • Voltage should now respond to battery connection
  3. Connect USB-C adapter
  4. Confirm:
    • Power source switches to Adapter
    • Battery begins charging
    • PPBUS rises appropriately during charge
