MacBook Pro A1706 Battery not recognized repair
Device MacBook Pro A1706
Affects part(s) Motherboard, battery
MacBook A1706 not recognizing the connected battery
  • MacBook not turning on.
  • Battery not recognized/charging
  • First, try a known good battery.
    • If it doesn't work, check the battery cable going to the board.
      • Sometimes there is corrosion here, sometimes the customer tore the bar on the connector off the connector.
  • In some rare cases the SMC still is a factor in battery recognition on this board.
