IPhone 16 Pro Max Restarting When Opening Camera App
Device iPhone 16 Pro, iPhone 16 Pro Max
Affects part(s) Logic Board, CPU
Needs equipment Soldering Iron, Hot Air Station, Soldering Wick, Microscope, Solder Paste
Difficulty ◉◉◉◉ Specialist
iPhone 16 Pro and Max devices experience repeated camera restarts when opening the Camera app.
The root cause is a damaged or missing crystal capacitor located under the CPU.
This fault cannot be resolved by software restore or peripheral replacement. The issue requires component-level repair under the CPU.
  • Camera app causes immediate restart
  • Device reboots when camera initializes
  • Device boots normally but crashes under camera load
  • Issue persists after:
    • iOS restore
    • Camera module replacement
  1. Confirm panic logs
    • Look for kernel panic related to camera or standby
  2. Reproduce issue
    • Open Camera app → immediate reboot
  3. Rule out peripherals
    • Test with known-good camera modules
  4. Board inspection
    • Inspect CPU underside area for missing/damaged capacitors
  1. Remove logic board from device
  2. De-Solder CPU from board
  3. Locate faulty/missing crystal capacitor(s)
  4. Remove damaged capacitor carefully
  5. Clean pads and inspect traces
  6. Install replacement capacitor from donor CPU
  7. Reassemble and test
