How To Fix an iPhone XS That Randomly Restarts | |
Device | iPhone XS, iPhone XS Max |
Difficulty | ◉◌◌◌ Easy |
Type | Part replacement |
There are many reasons that could cause an iPhone XS and iPhone XS Max randomly restart every few minutes. For the iPhone XS & XS Max there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone XS Series is:
- Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart. So if you see your iPhone XS says it's charging at 0%, that could be why it's restarting.
![](/images/thumb/e/ee/Panic_Log_List_ipad_4.png/235px-Panic_Log_List_ipad_4.png)
![](/images/thumb/9/93/Panic_Log_Prs0_iphone_x.jpg/235px-Panic_Log_Prs0_iphone_x.jpg)
If you see:
- Check the mosfets Q3201 or Q3200 to see if broken or damaged
- Check the battery data pins (I2C0_SMC_TO_GG_SCL_CONN and I2C0_SMC_BI_GG_SDA_CONN) for a diode mode reading. If it's OL, then there's a disconnected line & it'll need to be investigated
- Bad or damaged flex
