How To Fix a Samsung S22 Ultra That Does Not Power On
Device Galaxy S22 Ultra
Needs equipment multimeter, soldering iron, soldering station, microscope
Difficulty ◉◉◉◉ Specialist
If you have a Samsung S22 Ultra that does not power on.
Example image (Figure 1)
  • Does not power on
  • Shows no signs of life
  • Plug it into the charger & nothing shows on the screen
First you want to connect to known good parts. Like a new battery, new screen, new charging port
Then you want to check the USB meter to see if it's charging
If it pulls X ....
Then you can use a DC Power Supply & check the current draw before you prompt to boot.
If you have 2A current draw on the DC Power Supply before you prompt to boot, then you'll want to check for shorts on ____
Use a thermal camera or freeze spray to track down the short Example image etc.
