| Diagnosing Power Draws on Nintendo Switch | |
| Device(s) | Nintendo Switch |
| Difficulty | ◉◉◌◌ Medium |
Introduction
Diagnosing power draws on the Nintendo Switch requires a systematic approach for accurate testing. In this guide, we'll perform diagnostics without a battery, bypassing the temp sensor using a 10k resistor. Using a bench power supply set to 4.2V at 2A, we'll test various components and check for specific power draws.
- No Display
- No Sound
- Incorrect Power Draw
To find a solution to your specific power issue we need to follow a few steps to ensure we are testing correctly.
For this guide we will be testing without a battery and we will be bypassing the temp sensor by using a 10k resistor between the battery test pads next to the battery connector. Our bench power supply will be set to 4.2v at 2a (this is important as less than 2a will fail to reach second stage boot) and we will be powering via the VBAT test pad of the BQ24193 (Unless testing VSYS line for first stage boot).
Images to come.
