Apple T2 platform
Apple T2 platform
Device(s) Apple Laptops
Devices using T2 / T8012 SoC
All Intel MacBooks 2018-2020
Mac Pro 2019
iMac 2020, iMac Pro
Mac Mini 2018
Theory
Main functions:
  • SMC block: Battery charging, sensors management, power enables, and Intel S0-S5 state control.
  • SSD Controller: The T2/M1 MacBook SSD is essentially a sort of RAID array built on custom-produced Toshiba/Hynix SIP (System in Package) SSDs. Each SSD on board (often called NAND, which is technically not correct) contains its RAID configuration block. To read more, refer to the (upcoming) MacBook SSD Repair page.
  • Encryption processor: T2 has Apple's own security enclave processor (SEP), which is used for encryption, payment verification, authentication, and Touch ID.
  • eSPI controller: The Intel EFI image is stored on the T2 firmware service partition as a file; it is fed to the PCH via the eSPI interface. For example to clean ME region after Intel SoC/PCH replacement you need to use DFU Revive in Apple Configurator. This will practically rebuild EFI image on BridgeOS partition
  • Camera, Keyboard/Trackpad, Touchbar, Audio controller: Being basically a repurposed iPhone CPU, Apple reuses the audio codec, screen controller, and USB interfaces.
  • Power Controller: T2 is paired with a universal configurable power IC called CALPE. This chip has dozens of integrated buck regulators, LDOs. Unlike old platforms, it does not have direct enable signals but is controlled via the i2c interface. T2 itself also controls the GPU power sequence and gMUX.
  • Debug interfaces. T2 is also capable of feeding iBoot log as well as PCH/EFI Log into USB. It was used by Quanta with so called Potassium cable which worked as a debug terminal to read boot log of T2 / Intel PCH. Unfortunately since 2018 iBoot leak, Apple encoded all messages into stripped hashed message which cant be decoded. However PCH log is extrimely useful since it can pinpoint issue to RAM, GPU or other component depending on stalled block of EFI. It also shows full AHT log(Diagnostics on D button on start), listing all sensors and their values.
  • unlike old SMC, T2 uses 1.8V level for communication protocols. This leaves board with many level shifters which use two voltage inputs: the recepient and target ones. For example, if you had a suge on 3.3v you can expect them to fail. M1 would have 1.25V logic level, and, again, dozens of level shifters all around the board.
  • unlike usual laptops tradition where logical signal is usually always _L (low if active or enabled), logical signals are NOT inverted, which means high level (For example, DFU_STATUS is high 1.8v when DFU). LID signal will also be "LID_OPEN" and however despite being "iphone-like" screen, Touchbar neds LID_OPEN_L to be on.
  • Since T2 serves purpose of SMC now, full SMC reset would require DFU revive/restore to completely wipe battery charging log. T2 stores battery serialnumber and its charging stats in "SoC ROM" SPI Flash. It is also a good way to check history of the device, say if you are not sure if board was swapped or not.
  • Machine Serialnumber is stored on offset 28A000 of SoC ROM. Its presense is necessary for device activation if T2 has activation flag set after restore. Otherwise you will see error "Activation Server Cannot Be Reached". Do not try to change it to remove activation lock or MDM, that wont work and it wont be discussed in this wiki.
Firmware
Power Sequence
  1. "Finite state" stage, which does not require any activity from T2:
    • Main G3H power state generators, PPBUS, PP3V3_G3H_RTC.
  2. T2-Calpe power stage:
    • Main T2 power states, "S2R", G3S", "SLP" (not relevant to the Intel platform!),
  3. Intel Power stage (controlled by PCH/CPU System Agent):
    • S5-S0 power sequence is more or less standard for Intel platform, S5 rails are asserted by T2-Calpe, SLP_S3# and above is from PCH
    • all sys power good (VR_ON) is also issued by T2
    • EFI image is fed to PCH via eSPI interface.
T2 Power diagram
Powersequence T2 beta 0.1
Power Sequence
