How To Fix an iPhone 16 Pro That Randomly Restarts
Revision as of 20:04, 18 July 2025 by BCConnection(talk | contribs)(Added the code translation to HEX to help those use to the previous HEX address layout from Apple.)
There are many reasons that could cause an iPhone 16 Pro and iPhone 16 Pro Max to randomly restart every few minutes.
For the iPhone 16 Pro series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 16 Pro series are:
Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged with a drop & the back glass is breaks. Or when someone has repaired the back glass.
Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
After a back glass repair, the iPhone will restart on its own every few minutes
After a hard drop, the iPhone will restart every 3 minutes.
After a screen repair, the iPhone will bootloop every 3 minutes
After replacing the charging port flex, the device will auto restart on its own randomly.
The iPhone will reboot randomly when using it.
The iPhone will seem to freeze and restart every 2-5 minutes.
For this model, look for where it says "SMC PANIC - ASSERTION FAILED" ... "Sensor Array" ..
If you see:
3145728 and 2097152 (0x300000 and 0x200000 when translated to HEX) - It's related to the Charging Port Flex
Make sure this flex is plugged in
iPhone 16 Pro Max Air Pressure Sensor. If not connected or damaged, it will cause panic log 3145728Check the bottom mic/air pressure sensor module is connected
Check that no flex is torn, liquid damaged, defective
Test with OEM or Premium parts.
Aftermarket Flexes have a high defect rate
If water damaged:
1. Check the taptic engine. You can test with it unplugged.
2. Check the air pressure sensor module is not corroded or damaged
3. Check the FPC for corrosion or loose pins
Diode mode the FPC connectors for any fault
iPhone 16 Pro Max - Charging Port Flex is Bad. Sensor Array 3145728
It is also a good idea to keep a known good charging port flex in your bench, for testing only. There are reports of even NEW flexes being bad. So you have to keep known good flexes on hand at all times, so you don't waste your time troubleshooting with possibly bad flexes.
Bad or damaged flex
Low quality aftermarket flex
Other flex cables that are Liquid Damaged
Please note: You MUST have the required flex cables, (Charging port flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
