ClipperCreek HCS series
Revision as of 19:46, 10 July 2025 by Grundler (talk | contribs) (Added Eaton C25BNF240B relay)
(up to EV chargers section)
  • Power / Yellow
  • Charging / Green
  • Power Fault / Red
  • Charging Fault / Red
Relay / contactor information
Hongfa contactor seen in actual unit
Notes:
contactors for HCS series
60mm H x ~80mm L x ~50mm W
coil terminal tabs are splayed
no coil cover
has manual button override
American Zettler XMC0-402.ID data sheet from Zettler DigiKey ($10 for qty 1)
  • same as Zettler above but with "standard thermoset frame" instead of "compact thermo plastic frame"
  • visually looks the same
  • 66mm H x 84mm L x 50mm W
  • manual override exposed
  • coil is covered
  • tested with HCS-40 in Aug 2024, worked fine
Appli Parts APAC-240240 Amazon, $21
  • 65mm H x 82mm L x 55mm W
  • exposed coil
  • testing with HCS-40 in Oct 2024 ...
CGELE UPC ‎774297736354 Amazon, $12 inspected Aug 2024:
  • 65mm H x 88mm L x 53mm W
  • exposed coil
BlueStars LTC-2S-40 / 2P-40A-240V Amazon, $13 inspected Aug 2024:
  • 65mm H x 82mm L x 53mm W
  • exposed coil
Packard C240C unknown
Eaton C25BNF240B specification Ebay, $40+S/H From spec sheet:
  • 59mm H x 81mm L x 50mm W
Background / failure modes
  • High ground leakage
A common problem with Level 2 EVSEs in general is that the contactor welds itself closed. Typically not an issue with ClipperCreek though. OpenEVSE chargers like to do this later in life. After taking it apart and filing down the welds on the contact faces, you start just banging your fist on it real hard a couple times. Then power cycling it. That fist induced vibration was usually enough to break those welds, power cycle to clear the error, and get it working again for another month. Before it welded itself again. (will move this to OpenEVSE page later)
More product photos
inside view of HCS series EVSe, with back cover removed
lone PCBA inside the HCS series EVSE
