| PlayStation 3 Fault Finding Using UART | |
| Device | Playstation 3 Slim, Playstation 3 CECH‑L04 |
| Needs equipment | Soldering Iron, USB-TTL Device |
| Difficulty | ◉◉◌◌ Medium |
| Type | |
The Syscon when detecting a problem with a component on the motherboard creates a Error Log.
Using UART to communicate with the console we can request the Syscon to show us the Error logs stored in the console.
Required tools
In order to connect to the PS3 you will need a USB-TTL device doesn't really matter which one.
You will also need a few pieces of wires to connect the device to the console.
In order to connect the PS3 to your device you will need to solder 3 wires to the motherboard RX/TX and GND.
In order to pull the errors from the console we will need a program to communicate with the console, in this guide we will use SysconReader [1]
Connect your USB-TTL device to the computer, plug in the power supply of to the console and plug it in but dont turn the console on.
Next open the program and select the COM port where your USB-TTL is connected to.
Then there 2 types of syscon on PS3 Consoles Mullion (CXR) and Sherwood (SW) select the correct one according to the images bellow.
After selecting the right type of syscon click on Start.
After a click on AUTH and wait for a green text saying sucess if you get fail multiple times keep trying and if still falling check your wiring.
After AUTH sucess click on Get Error Codes and wait for the process to finish.
Expected output:
What to do with the Codes?
The most up to date database of syscon errors is on PS3 Dev Wiki [2]
