| PlayStation 3 Fault Finding Using UART | |
| Device | Playstation 3 Slim |
| Needs equipment | Soldering Iron, USB-TTL Device |
| Difficulty | ◉◉◌◌ Medium |
| Type | |
The Syscon when detecting a problem with a component on the motherboard creates a Error Log.
Using UART to communicate with the console we can request the Syscon to show us the Error logs stored in the console.
Required tools
In order to connect to the PS3 you will need a USB-TTL device doesn't really matter which one.
You will also need a few pieces of wires to connect the device to the console.
In order to connect the PS3 to your device you will need to solder 3 wires to the motherboard RX/TX and GND.
